The SCTP stack did not return the received message information.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Warning
Failed to get received message information. Socket ID = %p1%
| Name | Type |
| p1 | sInt |
